1971 Fastback KBY 217K winter 2016 tidy up
Re: 1971 Fastback KBY 217K winter 2016 tidy up
Post by sparkywig » 3rd February 2020 - 1:21am
Looks much cleaner without the holes.
muddy
Post by muddy » 3rd February 2020 - 9:05pm
Hoping so. Should look ok with some paint on. :D
Gutted tonight, busted my passenger wing mirror whilst trying to sort the floppyness :tear: :tear:
:( :( :cry: :cry: :cry: :evil: :evil:
I stripped the small stud thread. I might be able to cut it off and drill and tap a thread for a new stud. Otherwise I’ll be praying Danny Lord has one
Instagram: @type3.fastback
muddy
Post by muddy » 20th February 2020 - 8:23pm
Couple of updates.
i fixed my wing mirror, thankfully. I cut the old arm stud off flush, drilled and tapped a new hole and whacked in some new m6 threaded rod (with a bit of loctite). :D :D :D
Seems to be holding up pretty well. So I've been able to tighten both aspects of the mirror up so that it's no longer floppy and added a body seal to both mirrors.
Looks much cleaner with the seals fitted.
Pretty pleased with sorting this out. :nod: :nod:
muddy
Post by muddy » 20th February 2020 - 8:27pm
Also decided to paint my discs and calipers.
As they are Porsche pattern discs with Porsche spacers on too, I thought it'd look nicer them being the same colour, plus the new discs just get surface rust on them so easily.
Pretty please how they turned out.
muddy
Post by muddy » 20th February 2020 - 8:37pm
This weekend gone, I did a bit of work on the engine and engine bay.
I decided to get rid of the tired engine cover temperature foam that I'd held together with some silver foil tape during the resto. Fitted with some new stuff from ebay and a roll of silver temp cloth tape (Much better tape).
Pretty happy how it turned out.
I was also fed up of the engine cover being lop sideded when ever I hooked it up, so I fab'd another hook up and welded it on and painted it. The engine cover now sits nice and straight when open.
Next I tackled the intake manifold, as for some reason when I had the engine out and re-painted everything, the manifold silver went a bit funny :paranoid: :paranoid:
So, masked up and re-painted.
And then detailed the engine a bit by, using loom tape on some of the cables and wiping down all the dust that had accumulated.
Post by sparkywig » 20th February 2020 - 9:22pm
Nice work.
Have you got a link for the engine cover insulation?
Aaronslimvw
Post by Aaronslimvw » 22nd February 2020 - 10:26am
Tidy job! Bet you are a expert ar xmas wrapping after all that masking 😂
muddy
Post by muddy » 25th February 2020 - 8:17pm
Nice work.
Not the same seller, but looks the same product
https://rover.ebay.com/rover/0/0/0?mpre ... 119489272
I paid about £12, not sure why there’s no more on ebay at that price. Good stuff though.
I also bought some quality silver cloth tape from amazon Reinforced Aluminium Foil Adhesive Tap ... vEbVVTE1FZ
Post by broady_6 » 25th February 2020 - 9:26pm
Smart work! I need to do something similar with one of my mirrors. Id been trying to pin the bit of stud in, But if loctite works then ill do that. Much less agro! Forgive me for asking, but is it wise to paint the face of the brake disc?
The engine looks fantastic, is it still running a treat?
muddy
Post by muddy » 26th February 2020 - 7:54pm
The stud seems to be holding well. Only time and vibration will tell.
I’m aware that you shouldn’t paint the disc face was just easier to paint. It’s only a light dusting, and I intend to wipe it down with some scotchbrite before I fit the wheels.
Engine is running sweet. Although I’ve had a few plugs out this winter, so I hope it fires up and runs when everything is finished :?
muddy
Post by muddy » 29th March 2020 - 7:24pm
So been a while since my last update. Over the last 2 weeks I've been mainly bodywork and paint.
1. Fixed the previously poor work around the rear quarter torsion holes (and fit new cover plates).
2. Skimmed the sills so that the bodylines are a bit better.
3. Skimmed, painted the front/valance after welding up the holes.
I went to a localish Auto supplies who colour matched my fuel filler flap (Car had been previously painted back early 2000's but not to original colour)
Bought 2 litres of cellulose equivalent paint.
So here's some pictures.
I thought I'd take the opportunity to fit the sill chrome trim, something I'd never got round to doing when I did the original resto.
Was a bit nerve racking drilling into the panels, especially the new sills. :shock: :shock:
8mm holes to match the new clips I got (I think from Simon Kelley)
After paint though, the clips were ok fitting in, but the little centre piece you push in was really tight. So rather than open up the hole to 8.5mm I just used a hand file on the clips to give me some extra clearance. Worked a treat.
Also, whilst I've built an air tank build in the wheel well, I've fitted some M5 rivnuts so that I don't have to go behind if I ever need to remove the number plate and holder.
I'm by no means a pro painter, I'd say I'm competent, but I'm really pretty chuffed how it's come out. Colour match is fantastic, you can't even see where I've blended in to the rear quarters (After a flat and polish)
muddy
Post by muddy » 29th March 2020 - 7:39pm
Oooh, I hadn't realised I hadn't updated with pictures of the boot build, so here you go all finished:
Not to everyone's taste, but I like it alot 8)
Unbelievable amount of time to get to this stage, must be 4 weeks work? (Evenings and weekends)
muddy
Post by muddy » 29th March 2020 - 7:50pm
And I hadn't realised I'd not update with the front build progress either, so here's some pics:
Rubbed down my existing air tank and painted red, it's not come out too bad if I do say so myself.
Aaronslimvw
Post by Aaronslimvw » 1st April 2020 - 6:14pm
That boot is mega! Love it!
Post by broady_6 » 1st April 2020 - 10:04pm
Paint work is lovely, far better than anything i can achive!
muddy
Post by muddy » 1st April 2020 - 10:17pm
Thanks guys for the comments, much appreciated. Makes all the hard work worth it.
Will hopefully be finished the frunk this week, so will get some pics up of that soon
Aaronslimvw
Post by Aaronslimvw » 3rd April 2020 - 9:41pm
Just seen the frunk pics on your instagram. Looks top class that!
muddy
Post by muddy » 4th April 2020 - 9:22pm
Thanks appreciate it
Proper pleased how it’s come out. Going to take some pics tomorrow of the car out the garage. Shame I can’t go for a spin in it. :( :(
Post by broady_6 » 4th April 2020 - 10:36pm
Does look very slick! Theres nothing stopping you from using it to go food shopping. I've used my 944 for a food shop just to give it a run out.
Post by sparkywig » 5th April 2020 - 11:33am
I use the square for my shopping trips and visits to my Mum.
muddy
Post by muddy » 25th June 2020 - 4:05pm
In my excitement of fixing up my dream garage :D :D :D I totally forgot to upload some Frunk pictures.
So here you go......
Not quite happy with the suitcase install, so am currently re-working that during lock down.
muddy
Post by muddy » 25th June 2020 - 4:17pm
And here's some pics all finished showing, new momo wheel, gear knob and window winders as well as the front and rear speaker pods.............
Amazing what you can achieve when you throw money at something :badgrin: :badgrin: :roll: :roll: :roll: :lol: :lol: :? :?
Post by 937carrera » 26th June 2020 - 10:34pm
Amazing what you can achieve when you through money at something
Yeah, time and money can solve most things.
Do you know how much you have spent on her (not asking, just interested if you have done the add up)
