Daft Question,
When installing the rear sub frame plate that holds the large rubber bush at the V should there be any washers / bushes etc top side on the four corners?
I can see on the drawing that below has a washer and a spring washer.
Not 100% on the top side looks like you just bolt it up to the floor pan.
Rookie mistake, I seam to recall wrestling it out and dropping it all on the floor.
Any advice welcomed.
Rear subframe installation
- Attachments
- image0.jpeg (21.46 KiB) Viewed 1392 times
- Screenshot 2021-10-21 132715.png (35.28 KiB) Viewed 1392 times
Re: Rear subframe installation
No washers in between the plate and the floorpan, just the plain washer (load spreading) and the spring washer (to resist undoing) as shown.
