Hi all,
I'm refitting my tinware and fan to my new engine and the fan (Inner fan) is rubbing on the shroud. The gap is big at the top and rubs at the bottom. Any info on how to sort this? My fan does seem loose fit but is solid when bolted up.
Many thanks in advance.
Aaron
Fan issue
Re: Fan issue
Check that the inner fanhousing half is correctly seated against the block
Re: Fan issue
Make sure you've got the dissy clamp in place before you put the fanhousing half on, as the flap linkage bar goes over the top of the adjuster nut
