Front bump stop brackets
- DevonNotch
Anyone cut off their front beam bumps stops to take the car lower but kept the bump stop brackets metalwork??? I'm looking for a set to try to fabricate as both front beams we have as reference have both had their bump stop brackets removed
1972 VW Notchback
1978 VW Beetle Last Edition no. 164
1979 VW Bay Window Westfalia campervan
Re: Front bump stop brackets
The answer to the first part is no. But I may have a knackered old beam with stop mounts on. I will look in the week and let you know. Close up photos here
viewtopic.php?f=4&t=3094&start=200#p52708
- DevonNotch
That's awesome work - thanks for the photos, will be able to work from that for sure.
1972 VW Notchback
Im glad they help, I dont have any bump stops. I must have used the 4 I had to make 2 good ones. Best of luck
- DevonNotch
I've got a 2nd hand beam with the bump stops intact so will able to get a set fabricated if needed - thanks for the above link though - very helpful!
1972 VW Notchback
