Hi all,
I finally took the plunge and bought a type 3 fasty. Liked them for a long time and decide to go for it. I’m familiar with the type 1 and have a type 14 so I understand the basics but I’m learning how different a type 3 can be!
The car I have has been lowered and has a narrow beam, type 1. The drive is terrible. My KG is lowered but has a stock beam with adjusters so I’m ok with lowered - just not like this.
I’m after advice on the best option to improve the drive. I’m thinking of putting a stock beam back in and I gather I can lower that on the splines to give it a stance. If I do that I’m assuming I can improve the drive but I’ll need to get stock tie rods too - not sure where to find them.
Other options seems to be to go with a new beam, I see a number of sites selling them. They tend to be narrowed and pricey.
Any advice on getting a stance with a nicer drive would be appreciated!
Thanks in advance
BTW I would add a pic of the car but photobucket seems to have kicked off on one since I last posted on a forum.
Fasty too low
Re: Fasty too low
Hello and welcome.
Yes Photobucket changed owners a few years ago and broke a lot of forums. But you can still use flickr or imgshack.
I cant comment on decked out type 3s and ride. Mine is dropped by and inch and the ride is lovely. Im stock all round with new dampers. I never consider a type 1 beam, the type 3 beam is far more advanced and thus gives better ride quality.
Re: Fasty too low
Thanks Broady,
I’ll carry on with the stock beam plan for now. Still struggling to source all the parts - the long tie rod being the main problem. I’ve seen a site in the US which appears to sell them but I was hoping to source something closer to home.
I’ll look into flickr to imgshack later.
Re: Fasty too low
ideally buy a complete used type3 beam with trailing arms, tie rods - you can then replace BJs, seals and track rod ends. I have a type 1 beam going on my squareback - not due to the amount of lowering but the offset of the wheels. Have you tried raising the current beam? - if lowered too much the joints could be binding which will make the ride nasty...
Re: Fasty too low
It wasn’t so much lowered as slammed. It’s adjusted up as high as it will go but still too low for me. I’ll check the ball joints as they could be a problem.
I think I’ve sources a beam with trailing arms and hubs but no tie rods. I’ll pick that up on Friday and go from there.
- DevonNotch
Re: Fasty too low
If you can wait 6 weeks or so then I’ll have a complete 1972 type3 front beam for sale?
1972 VW Notchback
1978 VW Beetle Last Edition no. 164
1979 VW Bay Window Westfalia campervan
Re: Fasty too low
Thanks DevonNotch but I got a beam sourced already - otherwise I would have taken you up on that!
I’ve decided to fit a stock beam for now, but lower it a few splines. Then I’m going to revisit the Type 1 narrow beam at the later date. My priority at the moment is to get the drive right and enjoy it.
