Hi all,
Can anybody help with the below wiring. These run under the petrol tank. My brake master had two switches but this wiring has three lot if wiring....can any body identify what they are? My car is a 69lhd fastback and was an auto. Thanks
Wiring Help!
Wiring Help!
- Attachments
- IMG-20210618-WA0004.jpg (58.78 KiB) Viewed 3370 times
- IMG-20210618-WA0003.jpg (114.59 KiB) Viewed 3370 times
- IMG-20210618-WA0002.jpg (85.93 KiB) Viewed 3370 times
Re: Wiring Help!
More pics
- Attachments
- IMG-20210618-WA0006.jpg (66.29 KiB) Viewed 3369 times
- IMG-20210618-WA0005.jpg (71.52 KiB) Viewed 3369 times
Re: Wiring Help!
Red and black wires are brake light switches.
Looks to be solid white and black with a white stripe which are Head light and indicator respectively
https://www.thesamba.com/vw/archives/in ... 3_6870.jpg
you may be able to pick bits from different diagrams here
https://www.thesamba.com/vw/archives/info/wiringt3.php
Re: Wiring Help!
Thanks, but the head lights and indicators are all wired up already.
Re: Wiring Help!
Given theres lots of electrical tape wrapping. Maybe it something that was added late, a fuel pump possibly?
Re: Wiring Help!
Hi, It did have an electric fuel pump as was FI but I remove the wiring. I added the tape to keep the wires all together when I took the body off the pan.
I can't find a wiring diagram that has anything other then red and black wires.....
Re: Wiring Help!
Unless anyone knows better than me, the only thing you can do it trace them back through the bulkhead and see where they go. Not fun, but will answer the question.
