Choke Cover
KLiff
Choke Cover
Post by KLiff » 11th November 2020 - 2:35pm
My 1968 VW Type-3 fitted with twin- Solex 32pdsit-3 carbs have recently been refurbished by a garage in West London. After getting the car back and driving it around for a while I noticed that it was guzzling fuel and there was a trace of fuel on my drive. I took the car to another garage thinking I had a fuel leak and they told me that 2 of the 3 retaining screws on the choke cover on the right-hand-side carburettor were missing - that the choke cover was hanging off, being held on by only one screw. The other two must not have been tightened properly and shook lose.
They don't, however, have replacement screws.
Does anyone know where I can get hold of replacement screws?
Thanks,
Kevin
JSR-69
Re: Choke Cover
Post by JSR-69 » 11th November 2020 - 4:41pm
They will be a standard metric thread so take one to your local hardware store.
Judi
Judi R
1972 Karmann Ghia (sold)
1972 412 Variant Auto
Re: Choke Cover
Post by broady_6 » 11th November 2020 - 6:11pm
There is no choke cover as such, I assume you are refering too the retaining ring. Item 16 in the photo and the screw item 17?
The part number for the screw is 311 129 123, i think its M4 from the top of my head.
Im not sure how a loose choke would cause a fuel leak though?
Aaronslimvw
Re: Choke Cover
Post by Aaronslimvw » 11th November 2020 - 9:18pm
Happened to mine after a strip/re-build too! Just changed them for allen head ones.
richtbiscuits
Re: Choke Cover
Post by richtbiscuits » 12th November 2020 - 12:51pm
I might have few kicking around. I'll have a look for you.
'72 412 LE Variant
'73 412 LE Variant
'83 1200 Beetle
richtbiscuits
Re: Choke Cover
Post by richtbiscuits » 12th November 2020 - 8:08pm
Found a couple out from some scrap 32-pdsit carbs. PM me your address and I'll post them out to you.
'72 412 LE Variant
'73 412 LE Variant
'83 1200 Beetle
KLiff
Re: Choke Cover
Post by KLiff » 13th November 2020 - 3:27pm
Thanks all for looking. I found a specialist ironmonger on an industrial estate and they turned out to be 10mm M4 pan-head screws.
Alarming that they shook lose though...
KLiff
Re: Choke Cover
Post by KLiff » 13th November 2020 - 3:29pm
Fuel leak / guzzling is still a mystery though...
Aaronslimvw
Re: Choke Cover
Post by Aaronslimvw » 13th November 2020 - 9:45pm
Is the chokes set up correctly now tho? Fflap Fully closed From cold? And do they open when the engine warms up?
Re: Choke Cover
Post by broady_6 » 14th November 2020 - 9:51am
Have you got the nylon spacers? They arent shown in the image, but the screw is item 17, which fits through itme 16. then you should have a small nylon tube which slides over the screw.
