steering column bearing
gerrygerbil
Post by gerrygerbil » 28th May 2020 - 11:19pm
hi my 1972 squareback has slight play at the column my problem is i cant find a replacement bearing in stock any advice on a replacement and were to purchase would be great thanks graham
Re: steering column bearing
Post by purplepeter » 29th May 2020 - 10:11am
Post by broady_6 » 30th May 2020 - 3:15pm
As peter says, you will more than likely find the corrugated ring is at fault. Rather than the bearing itsself
gerrygerbil
Post by gerrygerbil » 6th June 2020 - 11:15pm
cheers lads sorted it , replaced the corrugated ring
