Type 3 Clock (late model) HELP!!
SimonB_notch
Post by SimonB_notch » 28th February 2019 - 4:52pm
Hi, recently bought this clock for my Type 3 Notchback and it doesn’t work.
Have looked at a number of the repair post online but can’t seem to find one for this later type of clock (think this is a transistorised electronic clock - has a date of 5.71 on the cover).
When I connect it up to a 12V power source the working parts start to work initially but then stop so power is getting to it i assume but something is stopping it from continuing to work (tried to add a photo but don't seem to be able to).
Only thing Ive done is spray it with a bit of WD40 as suggested on one of the posts on this forum.
Anyone able to help me out with suggestions on how to fix?
Many thanks.
Simon
Re: Type 3 Clock (late model) HELP!!
Post by purplepeter » 28th February 2019 - 5:19pm
Have a read of this!: viewtopic.php?f=15&t=76
Post by broady_6 » 28th February 2019 - 5:36pm
What website do you use to host your photos? guides here
viewtopic.php?f=26&t=14260
Id avoid WD40 on electrical components, it create a film on contacts which will stop it from working. Electrical contact cleaner is what you need, and lubricate moving parts with a graphite spray
SimonB_notch
Post by SimonB_notch » 28th February 2019 - 7:39pm
Thanks Pete and Broady.
Pete, thats the one i followed with the suggestion of the WD40. Maybe need to clean the points now....
Broady I use the iphoto thing on the laptop. Will take a look at the link.
Cheers.
Post by broady_6 » 28th February 2019 - 7:45pm
iPhotos is a photo editor, bit photoshop ect. Its not used for hosting photos online. You'll need something like photobucket, flickr or image shack ect
