Type 4 fuel lines around the fuel pump
richtbiscuits
Post by richtbiscuits » 3rd September 2019 - 8:13pm
Can anyone refer me to a good picture(s) of what the fuel lines from the fuel tank to the tunnel should look like on a type 4? I changed the fuel filter from a type 1 type to the square FI type yesterday and it's like a bowl of spaghetti under there with lines zip-tied together to prevent fouling the steering/suspension components. The filter bracket is still there but does the damper have a mount point or float free in the line? Anyone know where I can get a pump mount (the round rubber one with a stud on it) from? My top one has fallen apart. Thanks for any help you can give.
'72 412 LE Variant
'73 412 LE Variant
'83 1200 Beetle
Re: Type 4 fuel lines around the fuel pump
Post by 937carrera » 3rd September 2019 - 9:02pm
Rob 400e
Post by Rob 400e » 4th September 2019 - 2:04pm
I had the same issues when I replaced the perished fuel lines. A lot of pipe work in not a lot of space. On mine the damper was free floating, luckily the fuel pump bracket was good. However could you cobble something together from an ignition coil bracket? There is a fuel pipe diagram in... Henry Elfrink VW fuel injection tech manual. It won’t do much good, it’s just laid out like a London Underground tube map.
Type 411 Le four door auto .
1965 Beetle
Post by Editor » 2nd March 2020 - 2:23am
Rubber anti vibration mounts are supplied for electric motors. Looks like quite a selection on ebay. Check bolt thread needed and rubber dimensions.
richtbiscuits
Post by richtbiscuits » 3rd March 2020 - 8:49pm
Thanks for the idea. I'll have a look. I might look at making up some custom metal fuel lines. Safer and neater!
'72 412 LE Variant
'73 412 LE Variant
'83 1200 Beetle
