steering column bearing
hi my 1972 squareback has slight play at the column my problem is i cant find a replacement bearing in stock any advice on a replacement and were to purchase would be great thanks graham
Re: steering column bearing
https://www.veewee.co.uk/433vg0030
Unless yours looks like a corrugated ring https://www.machine7.com/product.php?xP ... 8361d5081f
As peter says, you will more than likely find the corrugated ring is at fault. Rather than the bearing itsself
cheers lads sorted it , replaced the corrugated ring
