Hi all the rubbers on my square are very dry any idea of any thing that could preserve them and soften them up a bit
Also there is some cracking on the fronts screen seal corners is there way to repair this
Rubber revitalising
Re: Rubber revitalising
Glycerol (glycerine) may help, soften them a bit, but needs re-application from time to time. Talcum powder is also a preservative for rubber, but if they're cracked, it's probably too late. I've seen black sealant coating used to some effect, but the corners do get bad first, as they're stressed there.
As unlikely as it sounds..Look on ebay for "Captain tolleys creeping crack cure"..Havent used it myself,but I've heard good things about it
This^^^very good stuff.
Mart
Mart
"A BLIND MAN WOULD BE GLAD TO SEE IT"
WWW.DBS-VW.CO.UK
WWW.CTTP.CO.UK
WWW.DBS-VW.CO.UK
WWW.CTTP.CO.UK
purplepeter wrote:As unlikely as it sounds..Look on ebay for "Captain tolleys creeping crack cure"..Havent used it myself,but I've heard good things about it
what were you looking for when you found that then Pete?
wenn es nicht luftgekühlt ist, dann ist es nicht cool
