Solex 32 Carburettor Gaskets
Solex 32 PDIST Gaskets made from Victor Rienz AFM43. This is a petrol resistant material. Details of the spec can be found here.
https://www.reinz-industrial.com/en/pro ... fm-34.aspx
They are suitable for a couple of uses before replacement is required. Ive run these for 2 years with out issue, as have a handful of club members. Ideal if you wish to take the top off the carb to clean any sediment, but dont want to buy a full rebuild kit.
Prices as follows, priced indivually so you can buy as much or as little as you wish.
1. Manifold to Head 1mm thick £1.75
2. Float bowl Top 1mm thick £2.70
3. Butterfly to Carb 1mm thick £1.75
4. Carburettor to Manifold 1mm thick £1.20
5. Choke 0.7mm thick £0.65
If you have any questions feel free to get in touch.
Re: Solex 32 Carburettor Gaskets
Hi I am interested in afew items you have.
GASKETS
2 of each. Except 4 of number 2.
No number 1.
GEARBOX MOUNT
Item number 29.
Is it split where the rubber is bonded to the metal?.
NEW SCRAPER £50
HOW MUCH FOR ALL POSTED TO DORSET
DARREN CLARKE
GASKETS
No number 1.
GEARBOX MOUNT
Item number 29.
NEW SCRAPER £50
DARREN CLARKE
Hello,
I'm not selling a gearbox mountt or window scraper. There aren't any listed in my advert above. But I am selling the gaskets.
The total for the gaskets posted first class is £23.
I assume you have some how confused my advert with Craig's? viewtopic.php?f=9&t=14993
Hi sorry new to this sute getting a bit confused where6u have seen things how do I buy from you?,
Just checking it is
2 of each
No of number 1
Thanks daz
Just checking it is
2 of each
No of number 1
Thanks daz
Sorry I was on mobile, Corrected price is £20.20. Drop me a PM with your delivery address and email address and we can sort paypal.
Hi sorry new to me this site how do I send a pm?
Hi sent you details earlier today. Await your reply thanks Darren
Re: Solex 32 Carburettor Gaskets / Heat insulation flange
I'm doing a rebuild on carbs at the moment ; I have a few questions
The bakalite ones in my car are 6mm, but the Paruzzi ones are 4 mm - which is correct ?
https://www.paruzzi.com/uk/volkswagen/e ... old/32134/
Do paper gaskets 1mm /1.5 mm go on either side of the heat insulation flange ? ie 2 per carb ?
https://www.paruzzi.com/uk/volkswagen/e ... fold/5237/
Manifold to head gaskets
Presume that the paper 1mm/1.5 mm gaskets are favored over the stock metal ones ?
Thanks in advance for any help..
paul p.
paul p.
Sorry for the delay, ive been out of the country. Ive had a quick look in the IPC. But that page is missing, typlically. But its safe to assume you would need a gasket on any sealing face.
I prefer the "paper" gasket because it can be used more than once, and had more tollerance for slightly warped faces from years of over tightening.
Thanks so if I’m correct…
So that’s a paper gasket on either side of the Bakelite heat flange
And the manifold to head gasket is better as the rock paper one…
I would assume a gasket either side, doesnt make any sense to fit oneside and not the other. But the information is missing from the IPC.
And as I say I prefer the "paper" one to the metal one. Other people may have different opinons
