project 72 fastty
fastty
Re: project 72 fastty
Post by fastty » 3rd March 2018 - 4:55pm
finally getting on with the chassis , got most of it mocked up in place.
and got the new front 195x35x18 tyres fitted
more soon.
early fasty bits needed
fastty
Post by fastty » 21st April 2018 - 8:28pm
finally made some decent progress.
got all the main frame in place and welded.
also got the front suspension cross member in postion and welded.
more soon.
Rob-type3
Post by Rob-type3 » 22nd April 2018 - 11:42am
Mental project this!
1964 Notchback
1970 Fastback
Post by broady_6 » 22nd April 2018 - 7:48pm
More smiles :D
Post by kaddy » 24th April 2018 - 10:22pm
Class 8)
fastty
Post by fastty » 20th May 2018 - 9:46pm
thanks.
bit more done.
got the engine sat in place to see what room there is.
looks like its just going to fit under the bonnet.
and got one of the top wishbones done
more soon
jmarkha1
Post by jmarkha1 » 20th May 2018 - 11:01pm
love the concept of a blown torquey motor like with rear drive.
If you hide the engineering - this thing is going to be a proper sleeper...
fastty
Post by fastty » 7th July 2018 - 8:20pm
thanks. :D
finally got chance to do a bit more this week, got on with making a rover v8 to mazda rx8 gear box adaptor and today i was able to bolt them together.
also got it sat in the fast back.
it still wants lining up in the correct position but it,s one step closer. heres a pic of a full side on
i think the stance is pretty spot on. :thumbsup:
Post by broady_6 » 13th July 2018 - 7:51am
Love it!
Angelo Amato
Post by Angelo Amato » 16th July 2018 - 9:21am
FAB! lovin the extend front wings :)
Rob 400e
Post by Rob 400e » 16th July 2018 - 9:22pm
You have skills sir, well done top job.
Type 411 Le four door auto .
fastty
Post by fastty » 17th August 2018 - 4:32pm
thanks guys,
bit more done, got the mk6 fiesta steering rack mounted and it works spot on.
got a full week on it next week so im hoping to get the rear axle in so more soon.
fastty
Post by fastty » 18th August 2018 - 4:13pm
got one of the rear wishbone jigs done today and laid it out with some cds tubing
the reason im making my own is the standard ones look horrid and are hard work to narrow as the rear axle needs to be 11" shorter than stock to fit under the fassty with the 10" wide rear wheels.
Post by broady_6 » 20th August 2018 - 4:37pm
Continue to love it, i assume they arent handed so you can use the same jig for both sides?
fastty
Post by fastty » 20th August 2018 - 7:50pm
no i need a left and right hand jig.
bit of a long day but i did manage to get the other wishbone jig done so tomorrow i can hopefully get them built.
Image.
even though its a lot of work building the jigs i need them as i intend to do more projects using the same set up so it makes it easier down the line.
fastty
Post by fastty » 25th August 2018 - 5:27pm
few pics from the last few days,
back axle in, tick
front chassis cross member, tick
now got to build some sort of support to hold the rad, wings, front panel and the bumper wants mounting to the chassis.
jmarkha1
Post by jmarkha1 » 26th August 2018 - 11:56am
skills :-)
oldtimer
Post by oldtimer » 26th August 2018 - 12:44pm
Oh my giddy aunt.......this is awesome . Respect sir.
Post by broady_6 » 31st August 2018 - 9:48pm
That thing is wild! are you going to make it like a dragster with a full removable front? or will it be a tube frame section which the panels fasten on to in a more traditional style?
fastty
Post by fastty » 2nd September 2018 - 8:06pm
cheers guys,
all the front end panels will bolt on just to make it easier to paint.
loads done this week so i will just put a load of pics on .
more soon.
Post by broady_6 » 9th September 2018 - 5:52pm
That is looking fine!!!
fastty
Post by fastty » 6th October 2018 - 5:32pm
been waiting for some parts to arrive and now there here i can crack on with the build.
first thing to do was mock up the bulkhead so it would give me an idea of where stuff is going to fit.
cut out the dash to give me access so i could put in a support bar to mount the brake servo and steering column.
from here i built the support bar.
next i made up the brackets that the brake servo would mount to. get this welded up tomorrow.
the support bar will also be the mount for a corsa b electric steering column.
will order all the steel sheet i need to make the bulkhead and all the floors on monday so im hoping to move the project along in the next few weeks. :D
