412 Variant estate build.
Re: 412 Variant estate build.
Post by broady_6 » 12th November 2023 - 10:03am
Admiration indeed! I was out driving my type 3 yesterday. The heater set just so. I meant to say, the "filler" in the blower box was actually a rubber type flexy sealent originally to prevent water ingress. Obviously years of heat and cold has turned it rock solid.
Ant B
Post by Ant B » 12th November 2023 - 11:49am
Yeah you can say that again, it was rock solid.
1967 Karmann ghia
1972 412 variant
ex AA van
vw caddy pickup mk 1
Ant B
Post by Ant B » 16th November 2023 - 7:42pm
Not got much done lately, mainly due to the blinking weather...rain, rain and more rain.
When it did dry out I managed to do some bits.
Got the blower box repaired, I ended up making a liner and welding that inside the old blower box.
I sealed the joints and tested with a bucket of water...all dry phew.
Had a test fit of the blower mechanism to check it all still fits ok.
I need to tidy it all up now and make it look neater, though you won't see any of it when the dash is back on.
Nice to make a step forwad with the project after days of bad weather.
1967 Karmann ghia
1972 412 variant
ex AA van
Ant B
Post by Ant B » 17th November 2023 - 3:16pm
Another dry day, yaaay.
Welded a repair section into the screen surround.
needs cleaning up a bit more yet.
Then
Welded another repair section in.
A little bit more done.
Still loads more to do.
1967 Karmann ghia
1972 412 variant
ex AA van
Dave Summers
Post by Dave Summers » 17th November 2023 - 3:37pm
That screen surround looks tricky. Blower box is neat but - maybe it's only that the camera angle doesn't show it - is there still a drain for the rainwater to get out (under the petrol tank)? (Mine was rusted in that area and we came very close to accidentally blocking it.)
Dave
412 Variant
411 2-door saloon
Ant B
Post by Ant B » 17th November 2023 - 7:06pm
Yes I made a new tube to fit inside the original outlet through the bulkhead.
Once I can get to the other side of the box (when I drop the tank)
I plan on welding up the other side of my box.
Screen surround is tricky, but a small bit at a time will see it done...I hope
1967 Karmann ghia
1972 412 variant
ex AA van
Post by broady_6 » 19th November 2023 - 9:29am
More great work!
Ant B
Post by Ant B » 22nd November 2023 - 6:01pm
I put my winter gear on and headed out to the drive.
Got the car turned round, so I can weld and grind without splashing gunk over the Karmann ghia.
I have some dodgy areas in the passenger windscreen surround to sort.
Still it will get done, slowly.
1967 Karmann ghia
1972 412 variant
ex AA van
Post by broady_6 » 26th November 2023 - 6:49pm
Looks very car like, always helps with the motivation!
Ant B
Post by Ant B » 27th November 2023 - 4:31pm
Welded up all the pillar.
Looks better.
Took a break from the car, well it was raining.
Started turning an old gun cabinet into a repro petrol pump/ storage unit for my man cave.
Cut a section out of the door and recessed it back a touch to make the back of the dial, will put glass over the front once it has been painted.
Made a handle for the door.
I have some mounting holes to weld up and then i can fit the hose and nozel, then paint it up.
Will sit on my work bench nicely and I can fill it with useful bits and bobs.
Tony.
1967 Karmann ghia
1972 412 variant
ex AA van
Ant B
Post by Ant B » 12th December 2023 - 8:23pm
Been working on my pump idea as the rain and cold has been orrible.
Nearly finished, just need to sort out the glass for the top and front.
Anyway the rain stopped and the sun came out...soooooooo.
The original front bumper is big, bulky and sticks out too far.
So I cut it down a bit.
Then I cut 5cm out of the width and reshaped the ends, so it fits tighter to the body.
If the rain stops later this week, I will sort out the mounts so it can sit closer to the body.
I like it anyway.
1967 Karmann ghia
1972 412 variant
ex AA van
Ant B
Post by Ant B » 18th December 2023 - 7:17pm
Lets trail fit the bumper shall we.
First repair some more rust holes.
Then before I could try the bumper, I took away the number plate mount.
Bumper on...for now.
1967 Karmann ghia
1972 412 variant
ex AA van
Dave Summers
Post by Dave Summers » 18th December 2023 - 10:28pm
Bumper looks good, but where are you going to fit the number plate?
Dave
412 Variant
411 2-door saloon
Ant B
Post by Ant B » 19th December 2023 - 3:14pm
Ahhh that is the next phase for when the rain stops...if ever.
1967 Karmann ghia
1972 412 variant
ex AA van
Post by broady_6 » 24th December 2023 - 8:03pm
Very tidy work there, nice and straight!
Ant B
Post by Ant B » 24th December 2023 - 9:24pm
Finished making the number plate mount and stuck it in the bumper.
Needs tweeking a bit in the new year, but this is the general plan for the front bumper.
Also started making the indicator blanking plates.
Merry Christmas.
1967 Karmann ghia
1972 412 variant
ex AA van
Aaronslimvw
Post by Aaronslimvw » 25th December 2023 - 8:31pm
Great work!!
vwfye
Post by vwfye » 26th December 2023 - 10:44pm
Nice delete!
Post by broady_6 » 30th December 2023 - 8:43pm
:D
Post by purplepeter » 8th February 2024 - 9:05am
I found this the other day & thought of you!
Ant B
Post by Ant B » 16th February 2024 - 5:12pm
Well I have finished deleting the original indicators and mounting the new ones.
Need to do some tidying up and I should be able to sand and fill the whole front end and get it into primer.
Then it is finish the sills off and drivers inner rear wing repairs and I could get the whole car sanded and filled and primered.
Mechanicals after that lot is done.
1967 Karmann ghia
1972 412 variant
ex AA van
Post by broady_6 » 7th April 2024 - 9:43am
Good work! I could never do that work outside, expecially at this time of year. Motivational!
