'67 Square continued.....
Locked
Re: '67 Square continued.....
Post by sparkywig » 12th December 2020 - 5:06pm
We have lights again, much brighter now the new front wiring loom and headlight connectors are all done.
New grommets as well.
Just in time, as I need to use the type 3 as a daily driver next week. Don't ask....
The wiring behind the dash needs a bit of work at some point.
vwfye
Post by vwfye » 13th December 2020 - 2:23am
Post by sparkywig » 22nd December 2020 - 4:03pm
As I was picking the squareback's new engine up from Suffolk yesterday, I had a socially distant parts run around Central England collecting a host of other goodies.
Post by broady_6 » 23rd December 2020 - 10:31pm
Some sexy toy there! Looks like 944 seats in the front of the bus too?
Post by sparkywig » 24th December 2020 - 1:44pm
Very similar, 1971 911 Carrera seats. Picked them up from a Porsche garage just North of Stamford for the princely sum of 100 English Pounds.
Everything else in the back of the deluxe bus is for the type 3.
Post by sparkywig » 5th January 2021 - 4:09pm
After replacing the nearside door lifter channel a short while ago, the offside window fell down as well.
New lifter channel and rubber installed today.
Post by sparkywig » 16th January 2021 - 1:45pm
Let's see if this works....
Post by sparkywig » 13th March 2021 - 2:29pm
Progress on any vehicle has been slow lately, so I'd thought I'd make a start on the new engine.
The first thing I do need is a good condition oil cooler though, or I may end up fitting a new Type 1 cooler and a remote oil pressure sender.
Checked and stripped a number of fan housings to get a good pair and a set of working flaps. These will go for media blasting and a clearcoat.
And the rest are scrap.
And progress has come to a halt on this again while I get all the little bits on my list, but the oil cooler is the biggest hurdle at the moment.
Has anybody got a cooler, the flap mechanism that fits above the barrels and a thermostat going spare?
jmarkha1
Post by jmarkha1 » 17th March 2021 - 8:29am
I have a type 3 cooler that came off my 30k motor - its perfect.
I went with a remote filter and cooler and modified the tinware to get good cylinder cooling.
I can get photos of the cooler to you if you're interested
Post by sparkywig » 18th March 2021 - 12:15pm
Thanks, it will be appreciated.
I'll pm you.
Post by sparkywig » 20th March 2021 - 2:21pm
Spent a couple of hours cleaning a pair of flaps and a pivot rod in the blast cabinet.
Most of that was waiting for the compressor to recharge the air tank though.
And after a quick coat of primer.
vwfye
Post by vwfye » 21st March 2021 - 3:33am
Post by sparkywig » 7th April 2021 - 4:15pm
Slightly more progress on the square now I'm COVID free and out of self-isolation.
Took a drive in the bus the long way round to the lockup.
I've come to a temporary halt on the engine while I await the delivery of some parts, so I thought I'd tackle the new fuel system.
Out with the tank, which was surprisingly easy. I can also tidy the low pressure brake pipes and clean up the normally hidden area under the tank now as well.
Oh, looks like the fuel pipe needs renewing anyway.
I'll need to fabricate a bracket for the fuel pump, any idea what stock FI cars with pumps used?
Post by sparkywig » 9th April 2021 - 7:16pm
When I changed the fuel pipes in the Type 3 engine bay I thought I would undertake an experiment to see if there was any "real world" difference between Cohline ethanol proof hose and a premium ethanol resistant hose. I used a tee piece and the fuel hose (blue text) to the left hand carb was ethanol proof and the fuel hose (yellow text) to the right hand carb was ethanol resistant. The two pieces of 8mm hose were equal lengths and ran the same route, and the clips were torqued as well.
After 15 months the results are in.....
Nothing to see
Some small cracks appearing around the hose clamp
Again, nothing visible on the ethanol proof hose
Much larger cracks appearing on the underside of the right hand hose
Bearing in mind that the car hasn't done many miles since the hoses were replaced, you can see that the ethanol resistant hose is anything but.
IMHO the Cohline fuel hose definitely worth the extra cost.
Post by sparkywig » 10th April 2021 - 6:09pm
Back at the lockup today, ready to fit the newly cleaned and painted thermostat, bracket and flap linkage.
Hmm, that doesn't look right.
The rod won't go through the smaller of the holes in the head.
Looks like I'll be running without a thermostat after all that mucking about trying to source a linkage.
Mocked up the tinware, inlet and heat exchanger.
Now the fixing tabs on the heat exchanger don't line up with the tinware holes.
Ate my custard slice and gave up for today.
And very nice it was too.
Post by broady_6 » 10th April 2021 - 9:31pm
Very nice to catch up, Ive not read threads for months! I love an engine build and I now fancy a custard slice. I know what im doing tomorrow :D
Post by sparkywig » 12th April 2021 - 9:12pm
Managed to snap the metal fuel hard line where it goes into the front of the tunnel, it must have been weakened and I'd rather it break now in the lock up with no petrol around than somewhere miles away from home with a full tank.
So now the plan is to replace it with a new 8mm hard line that follows the brake pipe route through the car and AN-6 hose and fittings at the tank and in the engine bay.
Post by sparkywig » 20th May 2021 - 4:06pm
New 8mm copper fuel hardline from under the tank to the engine compartment. Had to reroute the pipe over the rear seat mount and out through the bulkhead next to the heater inlet.
I'm using teflon/ptfe fuel hose with AN-6 fittings from tank to hardline and then from hardline to carbs, so after the tank was cleaned out a new filter sock with an AN-6 tank adapter was fitted.
Post by sparkywig » 20th May 2021 - 4:22pm
New electric fuel pump mounted on the beam, just needs the wiring terminated.
There was a clearance issue with the spare wheel well, but a couple of adjustments with a rubber mallet cured that.
Next job is to fit the tank and connect the fuel line to the pump.
Post by sparkywig » 20th May 2021 - 4:33pm
I picked the fan housing up from the powdercoaters as well today.
Post by sparkywig » 29th May 2021 - 4:39pm
At last, the fuel system is almost complete. Tank back in, fuel pump and relay wired and everything working apart from one AN-6 fitting I stripped the thread on. Once that's replaced I can fill it with fuel and drive it.
Pics to follow in a few days when I've taken some.
While the seats are out I can give it all a good clean and rust proof and tidy up, apart from the corroded corners of the floorpan. :(
So I'll just cut the sound deadening to size and lay it loosely along with the carpet, then I'll fit the new plastic pieces to the seat runners and get the seats back in.
I've managed to locate the pieces of engine lid channel I cut out to fit the IDF filters, so they can be welded back in as well.
Post by sparkywig » 5th June 2021 - 3:26pm
It's finally a running driver again.
Managed to finish the new fuel system and electric pump this morning. Then spent a couple of hours scraping and wire brushing the floors for a slap of rust converter.
Post by broady_6 » 7th June 2021 - 9:51pm
A happy man? :D The new unit looks very nice. Well settled in now.
Post by sparkywig » 7th June 2021 - 10:29pm
Be happier when the stroker engine is finally fitted, but yes, happy I can use it again.
Just need to get the tracking sorted and drive it through the summer.
Locked
