Casa de Fye's autos...
vwfye
Re: Casa de Fye's autos...
Post by vwfye » 15th December 2020 - 2:19pm
Been out of the area since the 7th. I get back on the 17th, then I get back after it.
65 Sunroof Notchback
vwfye
Post by vwfye » 22nd December 2020 - 10:49pm
Created space, last evening, around the car for the rear subframe swap.
Post by 937carrera » 24th December 2020 - 10:25pm
Definitely making progress :)
vwfye
Post by vwfye » 27th December 2020 - 12:57am
The wifey decided, rightfully so, that I should no longer be under heavy and awkward things alone. So, today I picked up a lift table and a 48" LED lamp and Thursday I picked up a pair of 6 ton 2" tall jack stands. I am set to "safely" finish pulling the rear subframe and installing the new one. No more hokey balancing with one hand and wrenching/pushing/pulling with the other.
vwfye
Post by vwfye » 29th December 2020 - 9:10pm
I used a ratchet strap last night to put tensio on the set up. This morning, it had released! Woot!!! Next is to unbolt the pivot pins and then start fitting it all to the updates subframe.
vwfye
Post by vwfye » 1st January 2021 - 6:21am
Oh the joys of custom things...
I was hoping to get the new subframe mounted to the IRS transmission tonight, but...
vwfye
Post by vwfye » 1st January 2021 - 8:03am
My goal was to have my subframe together, before New Years... 14 minutes to spare! Nothing is torqued, tightened or cleaned up, but it is installed!
Good night!
vwfye
Post by vwfye » 4th January 2021 - 2:10am
Never, ever, live in a house while it is a construction zone AND try and build a VW.
That is all...
vwfye
Post by vwfye » 12th January 2021 - 6:08am
So, my shocks didnt fit the lower shock mounts... panic! After hours of complicated or expensive or both solutions... doh!!! Raise the bolt holes in the mounts. Doh! Doh! Doh! That with shorter springs should let my rear ride hight as wanted.
vwfye
Post by vwfye » 17th January 2021 - 5:10am
Did you know that a t3 IRS transmission does NOT have mount holes in it to mount it to frame horns?
I do now! Doh!!!
vwfye
Post by vwfye » 24th January 2021 - 11:59pm
While trying to leave as much material as possible vs the picture above of an aftermarket unit, after an hour of careful cutting, i finally have a coilover shock in place. Now to match it on the otherside. Progress... sort of.
vwfye
Post by vwfye » 7th February 2021 - 4:52am
After spending time at a buddy's place with his skill on the lathe, my new smaller coil springs fit the end caps on the shocks. So, they went onto the assembly and everything clears! Tomorrow I hope to have the transmission mounts, well... mounted to the bellhousing.
Ant B
Post by Ant B » 7th February 2021 - 3:56pm
Nice work sir.
Looks the part now.
1967 Karmann ghia
1972 412 variant
ex AA van
4" scale foster traction engine.
vw caddy pickup mk 1
vwfye
Post by vwfye » 14th February 2021 - 1:27am
I finally got my new valves and support parts installed in my heads. 48x38 should allow some air movement.
vwfye
Post by vwfye » 16th February 2021 - 2:13am
Ok, finally have the rear sub completely together! Next time in the garage, I will install it
Aaronslimvw
Post by Aaronslimvw » 21st February 2021 - 8:53pm
Top work!
vwfye
Post by vwfye » 21st February 2021 - 10:09pm
Fiddle fartin with the go fast parts. I think I need bigger than 42mm venturies!
vwfye
Post by vwfye » 27th February 2021 - 9:38pm
Crazy day!
Went to install the rearend, all was fine for the nose. Then, went to install the shock perch bolts and everything was misaligned. 😳
I ended up having to lift the body just off the pan with my engine hoist and use a drift to center all the bolt holes. But...
Now, to adjust the suspension to where I want it. I have 4 inches of adjustment down from where it is now.
vwfye
Post by vwfye » 27th February 2021 - 10:43pm
5 min to adjust! More betterer 😎
vwfye
Post by vwfye » 28th February 2021 - 1:59am
More happiness!
