Post your Type 4 Photo URLs here
Locked
Post by broady_6 » 12th August 2018 - 10:25pm
First off Photobucket.
Post by broady_6 » 21st August 2018 - 10:54am
Follow these instructions.
Click on the curved arrow.
Post by broady_6 » 16th January 2019 - 7:30pm
Method 1.
Post by broady_6 » 16th January 2019 - 7:33pm
Google Method 2.
Locked
