master cylinder brakes,
Just for 411 and 412 stuff.
pmacs49
Post by pmacs49 » 16th May 2014 - 12:55pm
Well took the car for mot and its failed on a leak on master cylinder and as well the rubber is perished, does anyone know we're to get one, a master cylinder
He would of not noticed, if he had known how to open bonnet, :lol:
shawn71
Re: master cylinder brakes,
Post by shawn71 » 16th May 2014 - 5:43pm
The master is no longer available, surprise, surprise.
Best bet is to send it of to be rebuilt to pastparts or if its just the rubbers then possibly a repair kit is available but can't remember of the top of my head which one and then again it also depends on what master is fitted. It's never as straight forward as you think with a Type 4 :))
pmacs49
Post by pmacs49 » 16th May 2014 - 9:01pm
Well I rebuilt it using the pistons and seals Tec out of a t1, as it was the donor master cylinder was a new one I brought, and had put on the beetle, but never filled it hence problems trying to bleed it when I put it on, I suppose really a left hand t1 could of been use, as they are half the price of a RH,one. Or possible a repair kit for a dual circuit t1, cost about 26 quid from GSF. Either way I think I may be back in Buisiness,
Mr Mot man.
pmacs49
Post by pmacs49 » 30th March 2015 - 11:26am
I did have the master refurbed at pastparts, 118 quid returned,
3nero
Post by 3nero » 23rd September 2015 - 9:09pm
I've had the leaky clutch master ever since i bought my 412, and today i finally got my hands on a NOS master repair kit. It's part no.411.698.181A does anyone know if the kit is for the clutch master or the brake master or both?
I've tried looking the number up online but can't find any info. I can take some pics of the kit if that helps.
1977 Bay
1974 412ls
JSR-69
Post by JSR-69 » 23rd September 2015 - 10:50pm
According to the parts list I have, these are the repair kits:
Master cylinder: 411.798.045
Slave cylinder: 411.798.041 (from chassis 410 2000 001)
There is no combined repair kit listed.
Judi R
Judi R
1963 Beetle (rustbucket)
1972 Karmann Ghia
1972 412 Variant Auto
Post by Editor » 24th September 2015 - 12:30am
411.698.181 appears in my Parts book as tandem master brake cylinder repair kit 19.05 (mm bore). Sometimes the A suffix is a slight change of specification, and others it's a significantly different part. Since the 6 stands for brakes and the 98 for repair kit, I suspect it isn't for the clutch, which should start with 411 7....
3nero
Post by 3nero » 24th September 2015 - 11:04pm
Got pics...
more part numbers that didn't see before (time for specsavers maybe?)
1977 Bay
1974 412ls
3nero
Post by 3nero » 24th September 2015 - 11:09pm
Just seeing all the 3's now
Are these type 3 part's?
Btw this repair kit was orignally ordered for my car many years ago by it's orignal owner and found it's way to me the long way round and arrived out off the blue in my work post thanks to a member in one of our clubs over here. sometimes it's nice having the only type 4 on the block :D
1977 Bay
1974 412ls
Post by Editor » 25th September 2015 - 1:54am
I've not had a Type 4 brake master cylinder apart, but it looks like that in the parts book (very similar to the Type 3 too). The casting numbers are the part codes from ATE - not VW.
