This 1974 Model 412 Owner's Handbook can be found at
http://garbolandia.com/modules.php?name ... age&pid=54
The site is Polish I believe.
Details supplied by baby bleu.
412 Owner's Handbook on-line
412 horners hand book
oh, thanks ,,editor,,, i send that for to show what différent option ...m,code,,, you can buy in polish ,or north ,,, norvégian or something ,,, look the small vent window,, or the extra m,,code ,,, for front light wiper you have double wather tank in the front for that ,,baby..
That's on page 24 - a big washer bottle just behind the bonnet latch. They supplied a large washer bottle in the Type 3 but I don't think that headlamp wipers were available on Type 3s.
I couldn't find mention of them in the Type 4 Parts Book - maybe they were only listed in the Swedish or wherever handbooks.
Then again, I may be about to find out they did!
412 orner,s
you can see in the m,code page ,, extra wiper for head lamp on the 412 , with européan large lamp in the year 69-70 this européan front lamp was not export in the ,,usa,,or canada ,,that was the samething for the small vent window , only for europe ,,
- walkerdude2001
Nice to have a manual, but how the F^%$ do you open the fuel tank, i need to get some fuel in and run her a bit.....tried both keys, but it was at night...
I will try again this weekend, and see!!!
Have a nice christmas guysa and gals...
Jack
Jack
1963 vw Beetle - 1600 engine
1971 411 LE Estate 1.7 FI
1997 vw Sharan 2.0L
1997 vw Sharan 2.0L
The cover releases by pulling the knob under the RH side of the dash (you've probably got there OK). Usually they don't have a lockable cap, but if you have, try turning it the cap clockwise and the lock clockwise first to make sure it's locked, then turn key anticlockwise half a turn without moving the cap, and then try undoing it.
Not sure if yours has a bayonet or screw thread. If bayonet it might be best to push the cap on a bit as you undo. Could be rusted on the face, and gripping the rubber gasket tightly. I've sometimes needed some mole grips padded to undo . Spray WD40 nto the cap to make it easier next time.
If it has a screw thread, you have to undo a certain amount before it starts turning the thread.
412 horner
yes this is polish , i have this file ,, very nice 412 forum there too , and 412 picture , look the spécial ,,m,code,, small vent window for the front door ,,
