which cable for accelerator?
Which cable is it for a 73 412 please? Can't see anything listed on the parts compatibility list. Thanks in advance
Re: which cable for accelerator?
Think I uesd a Type 2 cable for mine when it broke last year
Thanks Shawn. I think mines stuck in the channel underneath somewhere, my guess is it's got a little caught or something when the engine was out. Fine at carb n pedal end, but stuck n revving the nuts off
When I had to replace mine it was a sod to thread through the bulkhead into the engine bay, maybe yours is sticking in the same place?
Evening, I'm pleased to say I didn't need the cable after all. In daylight the problem was obvious and an easy fix. The return spring on one of the carbs had broken. Who'd of thought that would sound so expensive when it went huh
Good news, far easier than the cable then
