If you haven't done so already...
Just for 411 and 412 stuff.
shawn71
Post by shawn71 » 12th March 2011 - 6:31pm
then I advise you to fit a second bonnet release cable as it's a right pain inthe a*** when it snaps and all your shopping is stuck in there :angry:
The snapping of the release cable prompted me this afternoon to run a second cable to behind the N/S light surround which is threaded through a small hole drilled in the light mount which is then connected to the release mechanism. This means if I should be unlucky enough to have the cable snap again I just need to undo two screws, the ones that hold the light surround, and then yank on the cable hiding there to gain access to the front boot. :D
Thus, this second cable alleviates the need to remove the light surround, remove the driving light and then undo the central bolt that holds the plastic cover in place inside the boot (which in itself is a pain). Once this done you would either have to reach your arm into the boot space through the narrow light opening and fumble for the mechanism OR reach you arm through the narrrow light opening to find the sheath/conduit for the cable, hope it isn't broken at the mechanism end, cut the sheath/conduit to free the cable in order to give it a good yank. All this faffing about results in a scratched forearm, lots of cursing, more cursing when you have to try and push your tool bag away the light cover inside the boot and then having to put it all back together :roll:
So, don't put it off, do it whilst you can still open the boot ;)
Re: If you haven't done so already...
Post by Editor » 14th March 2011 - 12:58am
Better than the Type 3 where a hole has to be drilled through the front panel!
ARCANE
Post by ARCANE » 14th March 2011 - 9:12am
Wise words Shawn, take heed everyone! I can vouch for this being an absolute ball ache which I never want to go through again.
WWW.DBS-VW.CO.UK
WWW.CTTP.CO.UK
BeeBabs
Post by BeeBabs » 14th March 2011 - 4:14pm
Pictures please? They explain so much better for a dummy like me:D (you can always pm them if yr worried about the secret being on the net)
shawn71
Post by shawn71 » 14th March 2011 - 6:10pm
BeeBabs wrote:Pictures please? They explain so much better for a dummy like me:D (you can always pm them if yr worried about the secret being on the net)
Give us a couple of days and I'll sort some pics for you Bee.
BeeBabs
Post by BeeBabs » 14th March 2011 - 8:21pm
8) Thanks :D
ARCANE
Post by ARCANE » 5th April 2011 - 12:50pm
Hi Shawn,
Did you get a chance to take some pics of your secondary release cable mod. If so could you post them up as im wanting to do the same on my car.
Thanks in advance
Mart :D
WWW.DBS-VW.CO.UK
WWW.CTTP.CO.UK
shawn71
Post by shawn71 » 5th April 2011 - 4:10pm
I'll pm you the details Mart rather than post up on here
