barrels n pistons?
Just for 411 and 412 stuff.
kyle
barrels n pistons?
Post by kyle » 8th December 2010 - 11:06pm
can u put the 2 litre barrels n pistons in a 1.7 or 1.8 type 4 without machining the block? and does the 2 litre crank fit in the the smaller blocks too?
cheers, kyle :thumbsup:
67 fastback
65 bug
KNOWLEDGE IS POWER!!
ar_kid
Re: barrels n pistons?
Post by ar_kid » 10th December 2010 - 9:11am
All Type 4 blocks are dimensionally the same, the 1.7/1.8 or the 2.0 crank will drop straight in as will the barrels but you’ll need to match the correct piston pin height to your rods, imagine the TDC piston position on the different stroke cranks. The only anomaly is the 1.7 head which would need opening out to take the bigger barrels.
http://www.tunacan.net/t4/tech/piston.htm
kyle
Post by kyle » 11th December 2010 - 12:20am
so i'll hav 2 use 2l con rods as well or else i will get low compression
67 fastback
65 bug
kyle
Post by kyle » 13th December 2010 - 8:40pm
how long r the 2l con rods cus if i cant get a set cheap then i will jus get some h-beam ones
67 fastback
65 bug
ar_kid
Post by ar_kid » 15th December 2010 - 10:12am
Rod lengths here… http://www.tunacan.net/t4/tech/conrods.htm
note also the smaller journal size on the 2 litre rods, they won't fit on a 1.7/1.8 crank.
