Can anybody tell me if the side waist line chrome trim on my 411 variant is the same as a Type 3 Variant im after an off side drivers door trim, it is 1cm wide and 115.5cm in length if you own a type 3 Variant can i be cheecky and ask you to measure the dimensions of the door trim please.
Cheers Mart.
411 Variant chrome trim
WWW.DBS-VW.CO.UK
WWW.CTTP.CO.UK
WWW.DBS-VW.CO.UK
WWW.CTTP.CO.UK
Re: 411 Variant chrome trim
Type 4 door is wider. I don't think you can very successfully shorten the trim - the ends are hard to get shaped and anyway the polished anodising gets damaged.
The only piece that is interchangeable is the rear Type 3 wing and 2-door Sedan I think. It is the same length but has a bit of a wrap round end, which I suspect would not be too hard to straighten, but you can get reproduction Type 3 trim, but not Type 4.
