412 clutch
Just for 411 and 412 stuff.
bfr123
412 clutch
Post by bfr123 » 1st February 2016 - 11:59am
Hi Guys, anyone know where I can get a clutch plate for my 412? I can get the full kit but I only require the clutch plate as I have a new pressure plate.
Brian
1972 412 LE 2 Door Sedan (taxed tested used)
1979 VW Micro Bus (taxed tested used)
1975 VW Micro bus Auto (deluxe model with steel sliding sun roof) Just building it back up.
Re: 412 clutch
Post by Editor » 2nd February 2016 - 1:34am
There are various combinations. You could try phoning Jane and Bryan on the farm in Kent - 01303840374 (workshop). I'm sure they will be able to sort you out, or at least give you some info.
bfr123
Re: 412 clutch
Post by bfr123 » 2nd February 2016 - 7:06am
Thanks Dave, I'll give them a bell.
Brian
richtbiscuits
Re: 412 clutch
Post by richtbiscuits » 18th May 2016 - 12:29am
I had the same trouble. Seems clutch plates, especially 210mm, are near impossible to find. I opted for relining at a local company. They did a cracking job at a very reasonable forty quid.
'72 412 LE Variant
'73 412 LE Variant
'83 1200 Beetle
Smokem_44
Re: 412 clutch
Post by Smokem_44 » 22nd November 2016 - 3:18pm
Literally just done this and couldnt find one at all...
Had to have it re-lined in the end...
Type 3 Squareback, Slammed late bay, 412 LE Variant and an ickle Fiat 126...
richtbiscuits
Re: 412 clutch
Post by richtbiscuits » 22nd November 2016 - 8:05pm
Shortly after my getting plate relined I found a NOS one on ebay, the vendor had three of them! I think Volksfarmers had the last one a week or so ago.
'72 412 LE Variant
'73 412 LE Variant
'83 1200 Beetle
bfr123
Re: 412 clutch
Post by bfr123 » 23rd November 2016 - 12:05pm
Had to have my clutch rebuilt as the center plate on the friction plate had split. All in all it cost me £138.00 including new friction plate and new pressure plate which was machined to fit the friction plate. This was great for the first few miles when I broke down as I couldn't engage gears. Seems like the slave cylinder on the gearbox has packed up as I have stripped the master and it seems to be ok.
Brian
richtbiscuits
Re: 412 clutch
Post by richtbiscuits » 24th November 2016 - 9:02pm
I'm pretty sure pastparts ans volksfarmers have clutch slave cylinders in stock.
'72 412 LE Variant
'73 412 LE Variant
'83 1200 Beetle
Le 411
Re: 412 clutch
Post by Le 411 » 1st September 2018 - 4:28am
I tried eBay Germany for rare vw parts my 411le has problems engaging gears mechanic rectified problem by upgrading the clutch return spring this worked for 3 months starting ti play up again new clutch has been fitted according to vender when i bought it last year
