Rubber revitalising
Triothreetrio
Rubber revitalising
Post by Triothreetrio » 18th July 2012 - 8:59pm
Hi all the rubbers on my square are very dry any idea of any thing that could preserve them and soften them up a bit
Also there is some cracking on the fronts screen seal corners is there way to repair this
Thanks 8)
Re: Rubber revitalising
Post by Editor » 18th July 2012 - 9:35pm
Glycerol (glycerine) may help, soften them a bit, but needs re-application from time to time. Talcum powder is also a preservative for rubber, but if they're cracked, it's probably too late. I've seen black sealant coating used to some effect, but the corners do get bad first, as they're stressed there.
Post by purplepeter » 18th July 2012 - 10:05pm
As unlikely as it sounds..Look on ebay for "Captain tolleys creeping crack cure"..Havent used it myself,but I've heard good things about it
ARCANE
Post by ARCANE » 19th July 2012 - 11:45am
This^^^very good stuff.
Mart
WWW.DBS-VW.CO.UK
WWW.CTTP.CO.UK
Clockwork
Post by Clockwork » 20th July 2012 - 7:03pm
purplepeter wrote:As unlikely as it sounds..Look on ebay for "Captain tolleys creeping crack cure"..Havent used it myself,but I've heard good things about it
:shock: what were you looking for when you found that then Pete? :lol:
