I'm wanting to get my 70 fastback low but just wondering what's the best way?
Iv been told to lower it as is but iv been looking at narrowed beams as this gives more clearance right??
Is it a mission to do??
Any help will be much appreciated
Nice one volkswalkervolkswalker wrote:click my link...scroll halfway ish and theres front and rear lowering in detail dude
viewtopic.php?f=4&t=4976&start=50
pm me if you need any info
hahaha no we don't want that happening!! did crack me up when i saw thatEditor wrote:Yes, don't want you doing what the President's car did - looked quite a jolt for the occupants!
sjc wrote:If you want to go really low then you need a type 1 beam.
Be aware though that it's a lot more involved and definitely a lit more expensive
You can lower a type3 for nothing.
If you want it slammed then you need to be budgeting 500 plus unless you can build your own beam.
I have just finished up my slamwerks conversion and with the dropped spindles it is a lot lower than you could realistically get on a standard beam.
Also been round the country side in it yesterday and it didn't bottom out once.
If you want to retain the stock beam I would say you should think about the bottom beam mount mod to increase clearance. They are only pressed steel so don't take to kindly to being dragged along the Tarmac
cheers man, sounds pretty easy when you list it like thatballbag wrote:Dude, I've lowered loads of aircooleds before now. I even built my own 4" narrowed beam for my bay. I just took my time.
I'm telling you now dude, you will not find an easier car to lower.
30mm nut - Undo and remove
Gently tap the balljoint out.
Lift drum and tie up out of the way.
Undo 19mm lock nut on torsion arm grubscrew
Undo and remove grubscrew with 8mm allen key.
Mark up splines for a reference point
Slide off torsion arm.
Replace after desired spline drop (1,2,3,4)
Reverse that list and to rebuild and then do the other side.
That lot took me about 15-20 mins, including jacking up the car and putting it on axle stands.
You'll fly through dude
pm'dsjc wrote:i have a spare pair of clamps if anyone wants them alreay pretty mashed at the botton so ideal for the mod
its all here dude ive done it last monthballbag wrote:Have you got any images of that dude, I'll be on to that
it sounds a lot easier than it is IMO....sjc wrote:The beam mount mod is fairly simple.
You cut of the part with the bottom bolt on
You weld in a threaded insert on the frame head.
Remake the missing piece of the clamp. Weld it together then bolt to the new threaded insert.
Job done and you gain about an inch of clearance.
