Wiring Harness/Loom
Wiring Harness/Loom
Anyone now where to get one? need costs for insurance Bollox
Ta
Ta
When I need one I was going to use this place http://www.autosparks.co.uk/index.php?cPath=292 they list a 72/73 one at £190, but I know they do specials to order as they did one for a T34 belonging to a friend of mine.
Mike.
Mike.
Not cheap, but if they insist............
http://cgi.ebay.com/ebaymotors/VW-TYPE- ... enameZWDVW
George
George
- aircoolsteve
well this is a bit of a coincidence! i needed a complete loom for my type3 square as the loom in it was more than a bit shabby. a fire in the waiting i thought.
so i was looking around for ages but as i was taking the whole car appart it was going to be quite a long time before i needed any wires.
i found a few that were just so overpriced (in the hunreds) that i even thought of putting the old one back in say after i'd done some repairs to it.
my car was a 6 volt and i wanted to change that to 12 volts so it made good sense to get a later loom and perhaps mod it here and there to make it work.
replacing a hole harness is an undertaking that should not be taken lightly. its a fair bunch of wires up front that will make you wince at first. you really need to take a segmanted attitude. that is, treat each circuit individually fuse by fuse. if you are using a second hand loom be ready for what the prevoius owners have done to it.
the loom i bought for £30 had the fuse box with it and was still connected to the wires. but not correctly! its out of a 1973 so was a bit different to the earlier looms. had 12 fuses as opposed to the 10 i had.
the thing about my rewire was that i could only find a rear loom from a 64 but it was in really nice condition so iv'e used it. the colours are the same. the trace colours wind round the late wires and are striaght on the earlier wires.
i'm fitting a type4 engine that runs an alternator so out came the regulator. i took an 8 wire loom connector from a moddern car and soldered everything properly and used that clever shrink tube to make a professional looking job. you will need a basic meter and few electrical tools, plus a lot of time. oh, and a wiring diagram you can get off the web.
so if you can get an agreement with your insurance guy and the front part of your loom is ok, its quite possible to replace the rear half.
i only have one thing that i cant sort out concerning the headlight relay so i will be posting it on here to find a remedy
good luck with it.
steve
good luck with it.
steve
