What distributor??
Aaronslimvw
What distributor??
Post by Aaronslimvw » 23rd June 2023 - 10:44pm
Hey, I wonder if anyone could point me in the right direction?
I am pretty fed up of the stumble my 73” fasty has as you pull off, caused by the 009 distributor someone has fitted to it.
I would like to change it for the correct dizzy but confused as to which one I need. The car is a 1973 that has been converted from Fuel injection to solex carbs. Not fussed about having electronic ignition but want the vac advance back.
Any ideas?
Thanks!
Re: What distributor??
Post by broady_6 » 24th June 2023 - 1:45pm
Any of the gemeric Vac ones that the usual suspects sell would be an improvement. If you want more original.
311-905-205L is a fairly common one which will work well with twin carbs. In period it was replaced with VW 311-905-205AB, Bosch 0231 163 008 > 311-905-205AC, 0231 163 018
VW 311-905-205G, Bosch 0231 137 017 or 018 will also work. Replacement part number VW 311-905-205Q, Bosch 0231 137 033.
Im sure you wouldnt struggled to pick an of those up and auto jumble. Strip and rebuild it to check bushes and springs ect. Then you should be away.
Aaronslimvw
Post by Aaronslimvw » 24th June 2023 - 5:06pm
Can always depend on you for a quick answer mate! Appreciate it!!🙌🙌
Aaronslimvw
Post by Aaronslimvw » 25th June 2023 - 8:48am
Any off the shelf dizzy’s that you would recommend? Is it worth while going electronic?
Post by broady_6 » 25th June 2023 - 8:27pm
Ive never fitted anything new so cant comment. Pros and cons. Electronic ignition requires no servicing. And claims a stronger spark. Negative is, if it fails all you can do is replace (if you carry a spare at the road side) or wait for recovery.
I had one fail and it was pain, id rather thave just been able to change the condenser. Its up to you.
jmarkha1
Post by jmarkha1 » 26th June 2023 - 3:30pm
Pertronix do a nice ignitor that sits inside the stock dizzy - it is fit and forget - just take a spare rotor, points and condenser in the spares (just in case). 009s are so mis used sadly - the off idle stumble is no fun in traffic.
Post by purplepeter » 28th June 2023 - 9:11am
Danny has a 205T at a surprisingly reasonable price, but You'd need to explain to him how to suck on the vacuum unit as he's not mechanically minded!
My personal oinion would be to always go with points- electronic is a pain to set up from scratch, there's no indication of failure or means of testing for failure
https://www.ebay.co.uk/itm/256122708770 ... SwIv9kKz6q
where are you AAron?
Aaronslimvw
Post by Aaronslimvw » 29th June 2023 - 5:26pm
The old man just told me he has a couple of old dizzy’s on the shelf in the garage we can try 😆🙈 , so shall have a go with them. Have also ordered a new electronic one to have a go with if all else fails. I’m in Tremadog North Wales Peter.
s.unsworth
Post by s.unsworth » 8th July 2023 - 11:46pm
carlosfandango
Post by carlosfandango » 8th August 2023 - 4:10pm
Might be too late on this one, but thought I would add to the electronic ignition debate.
My 912 had pertronix for a few years when I first owned it, had 3 failures, which were quite unpleasant (one massive backfire so big that it blew my rear seats forward!). I eventually fitted a 123 Ignition dizzy about 6 years ago, and it really has not missed a beat. Haven't touched it expect to check the rotor arm.
My Auto FI Square had issues last summer, one of the problems (amongst several) was a faulty contact plate. So I again decided to just go with the 123 ignition version (which they do for FI VW and Porsche cars) and it's been great so far. Absolutely no firing issues.
The drop in EI conversion (Petronix / Powerspark etc.) seem to fail at some point. The 123 ignition dizzy's are more expensive, but far superior in my experience/opinion.
Carl
__________________________________________________________
1969 Fuel Injection Automatic Squareback
1967 Porsche 912
Aaronslimvw
Post by Aaronslimvw » 24th March 2024 - 7:59pm
Just to close this thread- I ended up fitting a petronix electronic dizzy , and it honestly has never ran better. Way better on fuel too ! Bonus!
Post by broady_6 » 2nd April 2024 - 7:40pm
:thumbsup:
