Compression Test
deaceabea
Compression Test
Post by deaceabea » 19th July 2022 - 11:25pm
Hi,
Just done a compression test on each of the cylinders on my sick Variant:
Cyl 1 45 psi
2 40 psi
3 47 psi
4 46 psi
These seem rather low, would appreciate some comment.
Re: Compression Test
Post by broady_6 » 20th July 2022 - 8:21am
Yes theyre all but non existant. First thing to do is check your valve clearances are correct.
Post by purplepeter » 20th July 2022 - 7:57pm
And make sure the Battery is fully charged & remove all of the plugs
deaceabea
Post by deaceabea » 21st July 2022 - 8:50pm
I have re tested the cylinders using a proper tester not the Mickey Mouse one I purchased and all is well, with readings now around 140/150psi, one at 120. So crisis over.
Thanks to all who offered advice.
I still need to find out why it's not running properly but relieved it's not mechanical.
