I thought this may help someone.
I’m all for originality but my 412 glovebox was trashed.
Having no luck with a replacement I found an old 944 glovebox in my shed.
With only a little trimming with a Dremel this thing fitted a treat. It’s pretty much the same height and fits perfectly behind the dash. It looks like it was made for the Type 4 now!
I’m working on converting a factory dash knob to hold the cable , so I just pull it and the bonnet pops.
Can’t notice anything sticking out underneath when the glovebox is closed. Doesn’t foul any hoses or wiring and as a bonus you can fit more junk in. I know my glovebox lid needs adjusting - the 944 liner doesn’t fowl the lid.
Type 4 Glovebox liner. Replaced using Porsche 944 glovebox.
- Stevosquare
- Attachments
- 37913A36-EBBB-4D90-BE24-4D68DE1E7A3F.jpeg (193.52 KiB) Viewed 3804 times
- CFF12262-00FB-4310-AAC9-7512881396E3.jpeg (181.66 KiB) Viewed 3804 times
- 7FF2DE60-8E08-41A1-9B0A-8F7AA8A7FBFF.jpeg (168.35 KiB) Viewed 3804 times
1973 S.A 412 LE Variant red.
1972 U.S Karmann Ghia Coupé (Type 14)
1972 S.A 412 LE Variant Blue.
Re: Type 4 Glovebox liner. Replaced using Porsche 944 glovebox.
Nice piece of inovation!
Type 411 Le four door auto .
That's really good to know, I assume it was from an early 944, so 924 might also be an option ?
Looks like you have been busy painting the dash too
- Stevosquare
It was from an ‘87 944 S. So oval dash.937carrera wrote: ↑24th December 2020 - 10:21pmThat's really good to know, I assume it was from an early 944, so 924 might also be an option ?
Just takes a few templates to get the shape exactly right against the dash. And if I happen to find a good glovebox liner it’s all reversible.
Yes I thought I’d give it a go.
- Attachments
- C8E11DDE-7605-472D-A8C5-38B28DA4294F.jpeg (294.19 KiB) Viewed 3759 times
