411 brake callipers
Rob 400e
411 brake callipers
Post by Rob 400e » 18th September 2020 - 7:55pm
411 brake callipers, can anyone tell me whether these callipers are fitted to other VW ie bay window camper vans etc. May be needing a couple soon for my 1972 411. Outer seals have perished. Any pointer much appreciated.
Type 411 Le four door auto .
Re: 411 brake callipers
Post by purplepeter » 19th September 2020 - 8:49am
They don't fit any other Volkswagens, but repair kits & pistons etc are fairly easy to get hold of
https://brakeparts.co.uk/shop/VW/Varian ... 0Cylinders
https://www.ebay.co.uk/itm/FRONT-BRAKE- ... Sw6Ttc979v
Rob 400e
Post by Rob 400e » 19th September 2020 - 10:06am
Not the end of the world then. Thank you for that I have a solution.
s.unsworth
Post by s.unsworth » 10th October 2020 - 11:49am
Try Brakes International - brakesint.co.uk
email : sales@brakesint.co.uk
They are in Bolton and Rochdale. They do Budweg Reconditioned Calipers as new but with Stainless Steel Pistons and Repair Kits / Stainless Steel Pistons. I bought a Pair of the Reconditioned Calipers when I rebuilt the whole Brake System on my Type 3.
Steve
Rob 400e
Post by Rob 400e » 11th October 2020 - 9:01am
Cheers Steve, I bought a re build kit from brake parts but didn’t need to strip the callipers. Just removing the brake pads and spraying plenty of brake cleaner and gently depressing the brake pedal and forcing the pistons back has done the trick. No sticking on now. However the perished outer seal will I assume cause problems in the future.
