Pitman Arm
Maccattack
Pitman Arm
Post by Maccattack » 25th June 2020 - 12:34am
Hi, am I correct in thinking type 3s had 2 types of pitman arm.
1 - the steering track rods mount from the bottom of the pitman and the steering damper mounts to the pitman arm.
2 - the steering track rods mount from the top and steering damper mounts to the steering arm track rod.
Reason I ask is I fitted an aftermarket disc set up and the brake master is bigger. With the track rods mounting from below the track rods hit the brake line to reservoir.
Ak
