Largest as in, dimensions and Cold Cranking Amperes?
Or has anybody fitted a pair of batteries either side of the tunnel in parallel?
What's the largest battery you can fit under the rear seat?
- Aaronslimvw
Re: What's the largest battery you can fit under the rear seat?
Would love to know this too as the one i have takes a hammering with air ride bits etc
Yep me see my build thread. Used a split charger too. Use it for stereo and air ride
Instagram: @type3.fastback
I’ll have a look to see what battery type I fitted.
Funny you should ask. I was using this recently to find a battery for a car which was proving difficult.
https://www.puretyre.co.uk/car-battery- ... ion-chart/
So std fit 063 45ah and 380CCA If you are using original clamps then really the width is pretty limited to the original 175mm. You may get away with a couple more mm. Without getting under there and measuring the floor space to be certain i dont know but length wise 225mm may fit. And height can come up a bit with proper terminal covers fitted.
A 111 might just go in and would be a big capacity increase. I hope that helps
I have no battery holddowns on my floorpans, so I can go a little larger than stock. I'll need to measure the actual flat surface to get a base size.
