Single Circuit master cylinder
I believe I need to replace mine on my 64.
Is there any others that fit? I keep seeing Ghia ones they look the same and possibly beetle?
Any help would be great! I’m wanting to keep it all drums all around so I know options are limited.
Cheers Rob
Cheers Rob
1964 Notchback
1970 Fastback
1970 Fastback
Re: Single Circuit master cylinder
Why not fit a dual circuit master cylinder?
Yes you can, but you need to swap the brake fluid reservoir for a dual chamber one.
Here's a link with the part numbers - unique to type 3 and type 34 by the looks of things
http://www.type34.com/forum/mechanical/ ... build-kits
Mecatechnic have them in stock, sit down while you look at the price
So just run a dual cylinder and a dual tank then so many said you can’t run drums on dual so annoying
1964 Notchback
1970 Fastback
1970 Fastback
As already said, Your best bet is past parts, who will sleeve & rebuild your cylinder to the original bore
I probably have the rebuild kit, ( bag full of nos components, but you need to strip & measure what you've got) But, the chances are that your cylinder is knackered anyway, so not much point trying to rebuild.
https://www.werk34.de/en/hauptbremszyli ... 021-a.html
http://www.pastparts.co.uk/
I don't understand why you've been told you can't run dual circuit master cylinders on drum brakes.
Twasn't me that told him, but probably because of the residual pressure question
Pre '71 buses run dual circuit master cylinders on drum brakes, when you fit a disc brake conversion you remove the residual pressure valves to stop the discs binding.
And 70's beetles had drums all round & much the same instruction, so maybe Robins answer might be to fit a dual circuit cyl & add a rpv to the front line, though I suspect it might not make a lot of difference.
But I'd encourage him to check the bore of the 2 cyls first
He could also try proactively messaging people like Simon Kelley, Larry Collins & Paul Dickenson, all of whom are the most likely people to be sitting on a nos single circuit cyl.
