Just a quick question.
Is there a sealing strip that fits between the vertical wing section just in front of the doors and body?
Wing seals
Re: Wing seals
Yeah there is a sealing strip originally fitted. Part number is D19, theres some info about it here
https://www.thesamba.com/vw/forum/archi ... 891--.html
I suspect any close cell sticky foam will do, as long as it doesnt hold water, it will do the job
Re: Wing seals
Funnily enough, Justin asked the same question- Dave hall told him to use denso tape
viewtopic.php?f=31&t=8663&p=46282&hilit ... eal#p46282
Re: Wing seals
I've got a roll of 20mm x 3mm self-adhesive closed cell neoprene tape in the garage, so I'll probably end up using that.
Re: Wing seals
Now I know where that 1" x 1" foam came from.purplepeter wrote: ↑21st February 2020 - 9:19amFunnily enough, Justin asked the same question- Dave hall told him to use denso tape
