Loose cylinder headbolts?
- packers1712
Good evening everyone, I'm looking for some advice regarding the above subject. My car has some symptoms of loose cylinder heads and is running like a bag of spanners, oil like deposits on top of the pushrod tubes, occasionally drops onto 3 cylinders and lack of power!
My question is should I check and tighten if needed the head bolts inside the rocker covers if i can't get the upper bolts without removing all the tin ware or if I find loose bolts inside the rocker covers do I really need to pull all the tin ware and do all of them?
Has anyone had any experience with this before and successfully fixed it without pulling the motor and doing a top end rebuild?
Really annoyed with myself as the engine was out earlier this year having oil leaks fixed and 2nd gear syncro repaired!
Thanks in advance Doug.
Re: Loose cylinder headbolts?
Not something I have ever heard before. But you need to do all 8 nuts in the correct sequence otherwise you end up stressing the head and it wont seat properly on the barrels.
To be honest it sounds like its worth having the rocker covers off and check the two nuts which hold the rocker shaft on. Ive seen them come loose as people havent used vibration proof washers. That would give rough running.
- Aaronslimvw
Yea tin needs to come off in my experience.. did mine the other week.. most of them were loose around a quater turn. As said above.. they must be torqued in sequence
- packers1712
Aaron, did you manage to remove the tin ware with the engine fitted? What car do you have mines a FI notchback not sure if different variants lend themselves to easier tin removal or not? Did you have any symptoms or was it just a routine check?
Thanks Doug.
Thanks Doug.
- Aaronslimvw
Hey. Yes i did. Mine is a fastback on solex carbs. Its a bit of a ffaff but doable carbs etc needed to come off as well atms the altenator etc. Pain in the ass but doable.
- Aaronslimvw
Just checked them as i already had the tin off to change the oil cooler..
- packers1712
Ok, good to know, hopefully i'll get chance to have a look at the weekend!
Hopefully if they are loose i haven't done any long term damage running the engine with loose heads, as last time that I used it I struggled to reach 70 mph in it!
- Aaronslimvw
70! Lol thats good going anyway!
You should be able to do 70 with out any trouble. I used to use my car as my daily and regularly communted from basildon to lincoln at 70mph on the A1. Even this past week ive been belting along at 70mph on the M180. Ill admit my car seems happier at 65. But 70 is well with in the reach of these cars. Mine has been well beyond 70 on a GPS indicated speed.
The cylinder top tins are removable insitue, but its bloody hard work im sure ive had the left hand one off to change the oil cooler seals at some point years ago.
- Aaronslimvw
Oh yea broady she will do 70, just feels like your flogging it. Muuuch happier at 60-65
- packers1712
I managed to do the left hand head at the weekend, that was all I had time for, it requires lots of components to be removed in order to get access to the upper four head nuts! Of the eight four were lower than the specified torque hopefully I’ll get chance to do the right hand bank next weekend!
FIngers crossed for you, was the rocker arm nice and tight while you were in there?
- packers1712
It was and it got re-torqued too! I’m not even sure if this is the cause of my rough running but one thing at a time so as not to confuse what may have fixed it in the end!
I removed the ignition coil to improve access and noticed it had begun to show signs of leaking some of its oil, so if the head re-torque doesn’t cure the rough running that will be next on the list as a potential cause!
Doug.
Doug.
I could well be a series of small issues that have lead to it. But as you say, fixing things one at a time often gives a clue as to the root of the issue. Finger crossed its "simple" in the end!
- Dave Summers
Official maximum speed of 85 was generally reckoned to be a slight understatement, so a good engine should be happy at well over 70. Back in the mid 1980s a 1600 Variant was the first car I ever drove that managed to hold 70mph all the way up the Glenfarg bank on the M90. (My Dad's Maxi 1750 couldn't do it, although to its credit it was a good towing car.)Aaronslimvw wrote: ↑5th October 2019 - 10:57pmOh yea broady she will do 70, just feels like your flogging it. Muuuch happier at 60-65
Dave
412 Variant
411 2-door saloon
412 Variant
411 2-door saloon
