Cyclical binding sensation
Post by sparkywig » 8th July 2019 - 1:31pm
Hello hive mind, me again.
I've just installed a new gearbox with short axle conversion and disc kit.
I'm now getting a cyclical binding feeling and periodic noise from the nearside rear hub. We've stripped, checked and re-assembled both hubs but the noise and sensation is still there.
When rotating the n/s rear wheel there is no bearing play until you get to a certain point, it then goes as you rotate the wheel further.
Is this the symptom of a bent axle shaft?
It's the only explanation I can think of.
Re: Cyclical binding sensation
Post by purplepeter » 8th July 2019 - 1:53pm
Have a look at the alignment of Torsion Tube & drive shaft.. Are they absolutely parallel?/is the gearbox absolutely central?
There was a tool for doing that, with a U shaped bracket to go over the torsion tube & A L shaped one at t'other end with a turnbuckle in between, But a sash clamp works just as well
I know that doesn't entirely answer the binding, but it's a starting point
Beyond that, You've got the inner & outer bearings the right way around? & the Hubnut properly torqued?
Post by purplepeter » 8th July 2019 - 2:02pm
Substitute Axle tube for driveshaft! I was thinking IRS!
Might also be worth pulling the brake pads out to eliminate brake binding from the equation
Post by sparkywig » 8th July 2019 - 3:03pm
Done that Peter, tried it without pads. But then discovered the offside disc runs out as well. Eliminated this from the current problem, but next on the list. 🙄
Somebody else has suggested one of the fulcrum plates may have become dislodged in the diff.
Post by 937carrera » 8th July 2019 - 8:22pm
How old are the bearings ?
If roller bearings, is it possible that one of the rollers has developed a flat spot ?
Someone advised me recently that use of molybdenum disulphide grease can cause this (it's too slippery and the roller stays in one place wearing instead of rotating)
Post by sparkywig » 8th July 2019 - 8:47pm
If it's the bearing, wouldn't there be play at all wheel positions rather than just the one place?
I would prefer it to be a bearing issue rather than have to drop the engine and 'box again.
Post by broady_6 » 8th July 2019 - 9:09pm
If its as david has suggested and just one roller has a flat then the issue would only appear at one point. Rather than a uniform failure all the way around the bearing
Post by 937carrera » 8th July 2019 - 9:10pm
If all the rollers are round then no play.
If one of the rollers has a flat then there will be play on that axis
That was the theory anyway, I'm not necessarily convinced, but better to mention it for you to consider, here's a link
https://www.machinerylubrication.com/Re ... ght-grease
Post by broady_6 » 8th July 2019 - 9:12pm
Would it be woth disconnecting the driveshaft at one end and then spinning the hub in isolation of the rest of the drive train?
Post by sparkywig » 8th July 2019 - 10:14pm
It's swing axle Jim, the only way of isolating the drive shaft is to remove it from the diff.
I wish it were IRS, so much easier to work on.
Post by broady_6 » 10th July 2019 - 11:01pm
That'll learn me. I need to pay more attention!
Post by sparkywig » 14th July 2019 - 12:09pm
I’m now wondering whether the runout on the offside disc is causing the binding effect, and it’s the n/s wheel bearing causing the noise.
Post by 937carrera » 14th July 2019 - 12:17pm
Put the car on axle stands at the rear, wheels off (just to reduce weight and rotating mass on the drooping wheel), pads in/out and see what you can hear when the wheels are being driven
2nd / 3rd on tickover should be plenty
Post by sparkywig » 14th July 2019 - 1:02pm
Yes, going to use the 4 post wheel free ramp at Nick’s. But giving him a break from my vehicles for a few weeks.
