Type1 oil cooler
Aaronslimvw
Type1 oil cooler
Post by Aaronslimvw » 20th May 2019 - 9:56pm
Hey, the oil cooler on my late fasty has just failed. And i cant seem to find a new one? Can i fit a late type1 cooler without much hassle? I know the oil pressure sensor is not on the type1 cooler and that the bolt holes are smaller. Can i just enlarge those holes slightly and have the pressure sensor elsewhere?
Re: Type1 oil cooler
Post by broady_6 » 20th May 2019 - 10:43pm
I believe they are also thinner. I also can't think where else you would mount the pressure sender post oil pump on a stand and engine. You won't find a new type 3 cooler, but there are many second hand ones about. An ultrasonic clean is the way to go.
I may have one but ill have to check this week.
Post by 937carrera » 20th May 2019 - 10:50pm
You can also get them TIG welded up ??
Aaronslimvw
Post by Aaronslimvw » 21st May 2019 - 12:19am
Have just gave the one off the car a good scrub and it seems ok.... i will try it again with new seals i think and see how i get on.. meant to be using the car as my brothers wedding car at the week end so i hope it will work 😂
