Badge Clips
s.unsworth
Badge Clips
Post by s.unsworth » 8th December 2018 - 12:00pm
Not strictly Type 3 or 4 but still VW. I have bought Bonnet Badge Nylon Inserts from 2 different VW sources under the Part Number everyone says is correct 113 853 615 They do not fit the holes in the Bonnet of our 1966 Beetle. The Nylon Inserts are 4.8mm od. The holes are less than 4mm 3.8mm is my best guess. Was there a smaller used on older VWs anyone please ?
Ta,
Steve
Re: Badge Clips
Post by broady_6 » 8th December 2018 - 12:11pm
113 853 615 is for type 3 all years, so its a beetle part.
I assume this is what you are referring to?
https://www.justkampers.com/113-853-615 ... ype-3.html
s.unsworth
Re: Badge Clips
Post by s.unsworth » 8th December 2018 - 1:28pm
That’s them. But they will not fit our 1966 Beetle. Even tried leaving them in hot water to soften them up. The ones it needs would have to be 3.8 - 4 mm external 3.0 - 3.2 mm internal. The Pins on the VW Badge are exactly 3.2mm. Did all the measuring with a thing for measuring Drill sizes.
s.unsworth
Re: Badge Clips
Post by s.unsworth » 8th December 2018 - 1:29pm
Off out to the Pub now. 13 of us for annual family Christmas bash !
Re: Badge Clips
Post by broady_6 » 8th December 2018 - 10:33pm
shall see what I can find out, just wanted to be sure we were talking about the same part first :D See you tomorrow with a sore head then!
Re: Badge Clips
Post by purplepeter » 9th December 2018 - 8:44am
Has the car been repainted?
Megabug sell ones that fit
s.unsworth
Re: Badge Clips
Post by s.unsworth » 9th December 2018 - 9:51am
Yes. Body Off Resto September - October. I had considered that it might just be the thickness of the new Paint. Then I thought, no, couldn’t be. Maybe I’m wrong ? But I will not be doing anything to damage the new Paint. It will have to be the Clips that get modified first !
Only other suggestion is that I need N0120801 Metal Clips ? Maybe ?
s.unsworth
Re: Badge Clips
Post by s.unsworth » 14th December 2018 - 5:11pm
Got a set of the N0120801 Metal Clips that fit the Split Screen Van Front Badge. The holes in the middle are just too big to grip a Beetle Bonnet Badge, so back to square one !
Re: Badge Clips
Post by broady_6 » 14th December 2018 - 5:34pm
Sounds like mr purple is right, you need to file away some of the paint which has built up in the holes during the respray
s.unsworth
Re: Badge Clips
Post by s.unsworth » 15th December 2018 - 8:20am
I’d rather file the Nylon Inserts than my new paint !
Or just find some smaller ones.
Re: Badge Clips
Post by purplepeter » 15th December 2018 - 9:44am
It looks like Simon Kelley sells the inserts, so it's worth asking if His are genuine? https://www.ebay.co.uk/itm/VW-Badge-cli ... :rk:2:pf:0
Beyond that. I take it You've tried hitting them in with a hammer?
Or maybe find some used/second hand ones?
74westy
Re: Badge Clips
Post by 74westy » 16th December 2018 - 6:54pm
I had the same problem. Turned out the issue was filler, primer and paint thickness in the holes. I carefully reamed out the holes with a drill bit and painted the inside of the holes to prevent any rust. The nylon plugs push in and the badge goes right in with a firm push.
Craig
Craig
1970 Type 3 Fastback 1600TL Automatic (Australian assembled)
1974 Westfalia Camper 1800
s.unsworth
Re: Badge Clips
Post by s.unsworth » 28th December 2018 - 5:14pm
Thank you for the suggestions but as the ‘66 Beetle has just had a very expensive “ Body Off” and new Paint Job by IRVs VW Restorations, I will not be doing anything to the Paint.
I have found 2 different Vintage / Classic Car Parts On Line suppliers who list the correct type of Plastic Inserts in many different sizes. I’ll be going that route. 1/8” ( 3.175mm ) Badge Pin Size to fit 11/64” ( 4.366mm ) Panel Holes should be perfect.
