Breakdown spares?
Breakdown spares?
What do you carry? Points, condensor, belt, oil? That was the best I could come up with off the top of my head.
Re: Breakdown spares?
I'm rather famed for taking it to extremes,but have always believed theres no point having a toolkit,if you dont have it with you when you break down!
So in addition to the full toolkit,I always carry Cables,fuel filters,fuelpump,points,condenser,ht leads,fuses,bulbs,jumpstarter powerpack & assorted other stuff i've probably forgotten i've even got!
Feel free to elaborate what a full toolkit is please and thankyou
I have a 3/8 drive socket set. 7mm to 22mm with extensions breaker bar deep reach sockets. Pair of 10mm 13mm 17mm spanners. Couple of flat and Phillips screw drivers, Side cutters and long nose pliers.
Think that’s about all of it
... WD40 and duct tape? Isn't that someone's signature here (or maybe type3.org)? "If you can't mend it with duct tape, you haven't used enough!" And again, "If it moves and shouldn't, use duct tape; if it doesn't move and should, use WD40."
Duct tape = child control too. Been useful many a time at shows
- Danny Lord
AA* membership card......dont leave home without it
*other breakdown companies are also available
Danny Lord wrote:AA* membership card......dont leave home without it
Rac here But the time it takes them to gt to you n faff about before they decide to tow you..... Deffo some fixes are easy enough to do yrself and get's you back on teh road and home (hopefully) in time for tea
- Jane Terry
a small trolley jack is always useful for flat tyres.
And currently I am including a 22mm socket, a cross head screwdriver and a 5p peice
Jane, the prob I rang you about...it was teh ally plate under the seat. It had popped clean through. A 5p was exactly the right size and has solved the problem. Will check on it in a week to see how it's wearing, but the general consensus is that a 5p is stronger than the ally to start with. Time will tell
- Jane Terry
hi claire you must get that problem sorted. Bryan say there is a poxy piddly circlip and a nut that holds that shaft in place. It has happened because somone has removed the shaft and not fitted the circlip properly back in place. You need the paitiance of a saint to get it put back in the recess properly so it will probably happen again once it has worn through the 5p piece.
Probably should, but I have bigger fish to fry. It seems the bad running is due to running on 2 cylinders for some reason that is bound to be expensive.......process of elimnation starts with a leakdown test with Pete @funkenblitz.
BeeBabs wrote:Probably should, but I have bigger fish to fry. It seems the bad running is due to running on 2 cylinders for some reason that is bound to be expensive.......process of elimnation starts with a leakdown test with Pete @funkenblitz.
Look on the bright side...half your engine works
- Jane Terry
Or even better your tappets have closed?
If that means you can hear the air wheezing from the engine that would be a nice simple solution. It's looking like a loose head or has chucked a valve.
