louves - stock or mod?
Questions and general discussion on all things Type 3 & 4
bilbo
Post by bilbo » 9th August 2010 - 11:29pm
can anyone tell me if the louves running down the sides of the rear windows are stock or aftermarket?
i've seen a few fasty's like this, but not many. are they just for looks or are they meant to increase airflow to the engine bay? or do they just provide another water trap :D
scrapyards are for quitters
miketyp3
Re: louves - stock or mod?
Post by miketyp3 » 9th August 2010 - 11:35pm
They are standard on post 70 fastbacks, and are to provide through flow ventilation of the interior.
They basically replaced the pop out windows that were deleted for that year and yes they are another water trap...
edit: simular vents also appeared on Notch and Squarebacks at the same time.
bilbo
Post by bilbo » 9th August 2010 - 11:43pm
cheers mike, that explains why i don't have them '69, and confirms that i don't want them, an open window will do me :D
bilbo
Post by bilbo » 9th August 2010 - 11:44pm
just noticed this car has both louves and pop outs, drafty
Post by Editor » 9th August 2010 - 11:50pm
They ventilate the rear window area; '72 on I believe, though my '71 Variant has them so they may have come ina bit earlier.
Yours looks like '72 if that is the original front bumper as it's the cut back type that they also started fitting to the Type 1 Ghias from '72 (Aug '71).
bilbo
Post by bilbo » 10th August 2010 - 12:03am
not my car dave, if mine were that straight and shiny i wouldn't be taking the skin off of my knuckles
come next dub freeze though...
miketyp3
Post by miketyp3 » 10th August 2010 - 11:10pm
I had them on a 71. Its also mentioned in the 71 brochures so I think it must have come in for that year.
Pop outs would still fit (the catch mounting holes may need to be drilled) but they weren't offered as the venting system was designed to replace them.
Post by Editor » 11th August 2010 - 1:04am
My parts book seems to suggest that the Variant and the Notch had rear ventilation for '71, but doesn't show them for a Fastback, so I suspect the Fastback only got the vents later in the '71 model year or maybe only from '72 models (Aug '71).
miketyp3
Post by miketyp3 » 11th August 2010 - 6:59am
This Brochure dated 8/70 must be a misprint then
and my (pre August) 71 Fastback must have been something special then.
Post by Editor » 12th August 2010 - 12:03am
I'm sure your Fastback has lots special, Mike! How long have you had a real Type 3 then? ;-)
It's pretty damning evidence - OK, I'm wrong. Still can't find those little inside covers listed in the parts book - must be there somewhere.
miketyp3
Post by miketyp3 » 12th August 2010 - 11:37pm
That one was a long time ago Dave... In fact it was my first Type 3.
Those little vents on the inside are the same for all models aren't they?
inkedkitch
Post by inkedkitch » 13th August 2010 - 9:59pm
Thats my old fastback! I sold her the other week! :-(
She had louves and pop outs, didnt let a drop of water in.
If you cant fix it with duck tape you havent put enough on!
Post by Editor » 13th August 2010 - 11:39pm
miketyp3 wrote:...
The Variant doesn't use them - there's no headlining on the rear pillar as it would get damaged during loading and unloading. It has a grill with a lump of foam behind. I don't know Notches well enough to be sure of that part.
Post by purplepeter » 27th August 2010 - 10:58am
I've just come accross the vent covers by accident whilst looking for sills for bilbo!
part no:311819465
http://www.vwispwest.com/product.php?is ... =311819465
Post by Editor » 28th August 2010 - 12:50am
They specify them for the Squareback too. Must have trim on that part in the higher-trim spec then. $29.95 each??? What?
